Re: Minn Kota 65 runs backward
Someone has probably replaced the brushes in the motor and connected them to the opposite wires. You can either swap the connections at the battery, I'm assuming it's an AT 65? if so swap the cable connected to the momentary/continuous switch in the foot controller (the center is the ground). move it to the connector on the 5 speed switch. just swap those two connections and you'll be in business... or you can take the motor back apart and swap the brush/connections. It's DC voltage so as long as you turn the voltage supply around the motor will spin the opposite direction and if it's anything like my AT 70, the prop only goes on one direction.
