Minn Kota AP40 Foot to hand conversion.
birdgod
I have been search online for this project for a while now. a lot of people take about it and only one I can find did it. but it doesn't have a lot of info on what components are needed. so I decided to do it my self and do it as cheap as possible. Here are the pictures.
Original control
Open it up and cut the wire. The Yellow, Red Green wire is for rotation control,
Orange and Brown is for speed control
White is for On/Off control.
Black is ground, needed for all control to complete the circuit.
1 pc 10K OHM Linear Taper Rotary Potentiometer for $0.99
1 pc DPDT Momentary Rocker Switch
Cut 3/4" PVC pipe and flatten the top for controls attachment.
Cut holes. it is very easy to cut if you heat up the PVC, Heat also needed to flatten the top.
Controls installed
Roughly attached the wire for test. Will make it "nice" after testing. if you need the layout of the wire, I will post it later.
Completed.
Here is a video to show the test result.
GA_Boater
Was your foot control broken? Is it hard to hold a rod and the hand control while fishing and trolling at the same time?
birdgod
not really, I am used to the remote hand control on motor guide. I am making the handle into removable and the controller is palm size. I also use this motor on my Kayak. so it is much easier to have hand held. the handle is for putting it on the rod holder on the kayak. :)
birdgod
nope the controller can steer. the rocker switch turn motor left and right. going night fishing tonight to try it out, may shoot some video :)
lmuss53
Nice upgrade, there are wireless versions of that controller around. They take lots of c batteries and are as big as a paperback book, but they work. I've had AP motors since they came out, all the way up to my current 80 pound ipilot.
birdgod
Where can I get the wireless one? the AP40 I have is kind of old..... I am thinking of make a wireless control my self :).
lmuss53
I doubt if you can buy a new one, The one I had was at least ten years ago, they have a receiver that plugs into the stock plug on the motor and the big remote. I looked around, I can find them for the V2 models but not the older ones with the flat head. I'd watch ebay for an old one.
