bktheking
- Joined
- Jul 29, 2008
- 5,057
Re: Minor Help Needed 1987 Evinrude 15HP 2-Stroke
Ok, so 2 carbs, same symptoms on both. That pretty much rules out a carb issue. How do the plugs look, soaked or dry. Have you tried running it on one plug, try top first , then bottom? Reed issues can be misleading, good compression, good spark- bad idle. Could be upper/lower crankcase seals as well.
