Missing, sometimes, not all the time?
slorebo
My 1990 200 XP Evinrude misses occasionally at idle in gear, when this happens I walk back to the primer bulb and it doesn't seem to have much if any fuel. My question is, could a bad primer bulb possibly allow air into the fuel pumps possibly causing the engine to miss?
Hooty
Re: Missing, sometimes, not all the time?
After the engine is started, the primer bulb won't be full. It'll just has fuel moving through it. If there's a leak anywhere in the fuel line it can/will cause problems. Instead of the fuel pump pulling fuel to the engine, it'll suck air.<br /><br />c/6<br />Hooty
dolluper
plugs or wires show up bad at idle and seam to be fine at higher speeds when less spark is needed this is a tought if you have no fuel leaks
