455 Evinrude
Thread starter- Joined
- Apr 29, 2008
- 6
So is my 10 hp Evinrude a 1960 or 1962 model? The mounting bracket says #10020, the engine "freeze plug" says #10024. I want to order the right service manual. Or is there not much difference between the 2 years?
I want to disassemble the lower unit and put new seals in, maybe replace the impeller. The lower unit was 2/3 water and 1/3 lube when I got this boat. I refilled, put new washers on the fill and drain screws, took 'er out for a short spin and ended up with tapioca colored goo for lube. I see orange permatex on the lower unit where seals ought to be.
Thanks.
Thanks.
