modified v vs jon boat
cowboy9from0hell
hi all! im looking into buying a boat. im looking for a 14 or 16 foot boat and i was wondering what the advantages and disadvantages were between a jon boat fron and a modified v boat front were?
lncoop
Re: modified v vs jon boat
I believe some clarification is in order, cowboy. It's generally accepted that john boat and modified V aren't mutually exclusive. Welcome aboard.
FunInDuhSun
Assuming you're talking about both having a flat bottom- with the only difference being the mod-V at the bow.
Flat-front jon boats don't take waves/ wakes well, causing a very wet ride. The mod-V tends to slice oncoming waves at trolling speed, but can still be a wet ride on plane.
I like a mod-V jon boat for backwater fishing.
cowboy9from0hell
the only reason i brought this question up is because if beenreading on the internet the for jet motor rigs that the jon boat style supposely allows you to run shallower water then what the mod v would. because im considering making my own jet rig. a 2010 left over 1452 cdl weld craft with a 60/40 jet or buy a 40hp prop motor then buy a jet lower unit for the prop so i can switch the lower units in and out for river and lakes
lncoop
Cowboy, I think you're confusing a modified V with a V hull. A modified V will run just as shallow as any other john boat because it uses the same flat hull design. What makes it a mod V is the V shaped front, as fun said. Either design will be equally good in skinny water.
John_S
Most mod-v jonboats I've seen do have a slight V all the way to the transom. It is like that on my 1648 DMI: http://www.joefishin.com/JonBoatProject.html
I haven't looked at jets in a while, but thout a slight mod v at the transom was prefered for less turbulant water and better pick-up (suction) of water.
As far as drafting through skinny water, doubt the 1-2" lower will make that much of a difference.
Lower unit prop to jet drive changes are not something you want to do on any regular basis.
Home Cookin'
You're right that traditionally, a jon boat (not John) has a square bow and flat bottom. However, nowadays, a lot of people call a small (12-14) open hull boat a jon boat, even with a deep V or modified V. But there are jon boats over 20'
In theory, the flat bottom can run in shallower water and the V "slaces through the waves." In practice, especially at 14', they draw about the same and a 14' boat isn't doing a lot of slicing. But look at the deadrise at the stern, and you will see how much more the various V hulls require.
As for skinny water, it's not so much what you can run in, it's what you can pole in, or walk the boat across. An extra 2" does not determine whether you run full speed on a plane over 6" of water.
the real advantage of the jon over the V is that the jon is way more stable, which is important in a small boat for fishing or that you will be moving around in to pole, etc.
Look at the Chincoteague Scow--that is a superior design, combining the best of all worlds: seaworthy, flat, light, stable, shallow draft.
BRICH1260
The difference between the two has been covered above. To determine what is best for you you need to consider what type of water you are planning on boating on and what are the characteristice of that water. Pick the semi v if the water gets rough, the jon if it is generally tranquil.
robert graham
My 1870 Express MV jon boat has a 6 degree deadrise at the transom and a pointed bow, it rides better in a chop than a plain "flat-bottomed" jon boat, but it's still a hard ride in most rough water. When the water is rough or with a chop I mostly just have to slow way down and just barge my way through it, but since we're mostly on rivers, streams and smaller lakes, it's not much of a problem. The flat or flatter bottom boats are very stable for fishing, hunting and utility purposes. You just need to buy the best boat for your usage. Good Luck!
robert graham
Also check: Express Jon Boats and Sea Ark Boats for lots of information on various hulls...
cowboy9from0hell
well right now im looking between a weldcratf 1452 cdl, 97 cajun special 1444 marsh runner with a 40hp merc and a 96 fisher hawk 2v 15ft with a 40 mariner magnum
