old time boater
- Joined
- May 20, 2009
- 2
I have a '73 50 hp Evinrude. I have replaced the ignition switch and solenoid. The motor will start and run well, if I start it by jumping across the solenoid posts with the ignition on. The electric choke works with ingition on. When you turn the key to "start" nothing happens, no clicking or any other sound (that I can hear). What do I check next? Are there tests that I can perform to verify a problem without merely throwing more parts at the problem? Thanks in advance for any suggestions.
