More Than 10% Differential - How Bad Is It?
jay_merrill
In another thread, I described a 1974 Evinrude 85hp motor that I picked up "on the cheap." I've had it for a few months, but just got around to working on it. The first problem that I ran into, was very low compression - about 30 psi on all four cylinders.
A couple of the very knowledgeable guys suggested stuck rings, so I applied PB Blaster directly into the cylinders multiple times, over a three day period. I also ran a can of BRP Engine Tuner through the motor, in two different applications. This was done by shooting the stuff down the carb throats, while spiining the motor via the starter, and by direct application through the spark plugs holes.
I now have 110 psi on cylinders 2 through 4, but only 90 psi on cylinder 1. We talk about the 10% differential rule a lot, but since I can probably get this motor going for very little money, I guess I am considering just "going for it."
So, my question is, "just how big a deal, is a 20 psi difference in one cylinder likely to be, given that none of the numbers are extremely low and three are actually pretty good?" I guess I expect a little roughness, but what else might I expect?
1946Zephyr
Re: More Than 10% Differential - Hopw Bad Is It?
I would just run it for about an hour or so, with a little extra oil in the mix and see if that will loosen up the rings and get them working good and free again. Then take another compression test.:cool:
jay_merrill
Re: More Than 10% Differential - How Bad Is It?
Bump - any other words of wisdom?
ezeke
Sounds OK to me. It would be worth the time to pull the cylinder heads; you could have surface rust on the cylinder walls that could be removed.
tx1961whaler
+1 on that
I'd double up on the oil (like during a break-in period) and run it for a few hours.
