GT1000000
- Joined
- Jul 13, 2011
- 4,916
Re: More transom problems, need some advice
My understanding of this long shaft, short shaft, etc. is that you are right on the money...Generally speaking a 18-23 inch transom, equals a 20 inch shaft, a 15-18 inch transom equals a short shaft of 15 inches and a 23-28 inch transom equates to a 25 inch shaft...or so I have read...so, you should be fine, also, if I am not mistaken...you can drill the motor mount bracket holes little up or a little down, to get your cavitation plate, pretty much even with the planing part of the hull...I don't think a centimeter is going to make that much difference, unless of course you are racing, in which case, micro millimeters start to come into play...and the expense starts to climb exponentially...Hahaha...
If you don't hear from one of the more knowledgeable guys soon, send oops! a PM and he will help you decipher this out...
