DayCruiser
Ensign
- Joined
- Sep 24, 2004
- 953
Re: Motor Attempts To Stall
Ok,I checked the wires and they look brand new. I put them on the middle of last year. I sanded the terminals on the coil and checked the other connections and they look ok.<br />I will go back and check the spring. Now it doesn't swing back and forth when its in neutral. But it doesn't close when the button is pushed in and the throttle is pushed forward--just can be pushed back and forth as well as when button is out and throttle is pushed forward<br />I saw where you told somebody on here to check for fire by putting a well insulated screw driver in the spark plug wire head and then touch the shank to ground and see if there is a spark.<br /> Might have been my mistake to think I could do it with this type of electrical system. Because now it might turn over and then you might just get a clicking sound coming from the starter area.<br />When I tried to get the spark by grounding it it didn't make a sound--no turn over or nothing. The first time I did it it went back to normal. This time it went to clicking over and over and then you let it sit it will turn over. I hope I didn't f-up something else. Just be my luck
