HT32BSX115
- Joined
- Dec 8, 2005
- 10,083
Re: Motor got hot smelled electrical burning
Yes, you're right. It IS crazy........but that's the way it is with a lot of models of OMC (and other obsolete) engines and drives.
The "After-Market" supports a LOT of engine/drive combinations......some better than others.
For example, OMC offered the 460 only from 87-89. They didn't sell a lot of because they were expensive. Now that there's no OMC........ Osco, Barr, GLM, etc, don't see any profit in making manifolds for them at all. So they don't.
There's a few people that are making (hand made) stainless steel jacketed headers, and there's a few making adapter plates to adapt 454 BBC manifolds to the Ford heads.
There's even someone that is actually making 460 aluminum heads with a BBC exhaust port pattern!
But it's just not worth it to do it because you have a fortune in it after you're done.
Now that you have a new engine, it may be worth it to switch.
Find a donor boat with a cracked block and a Mercruiser V-6/Alpha setup and swap it all over and use your new engine.
Your Cobra is worth something too. I removed all my Cobra stuff and sold it piece by piece. When it was all said and done, I recovered almost $3300! ($1400 for the drive alone)
Another way might be to scrounge a gimbal mount and get a new SEI drive. that might be harder because you will need to get all the other "stuff" like the trim pump, brackets, (Mercury)manifolds, etc.....
This is why a LOT of us on here (when asked) always try to steer people away from old OMC powered boats.......
