Motor Hiegth
joeken
I have a 19 ft randall craft bassboat with a 12 in. set back jackplate. Never had a jackplate before and was wanting to know how much higher is the motor set than on the transom?:confused:
Daviet
Re: Motor Hiegth
You need to look at the cavation plate on the engine, it should be even or slightly higher than the bottom of the boat.
joeken
Re: Motor Hiegth
I was under the impression that the farther back the motor sat, the higher you could set the motor. As the water exits the rear of the boat, the water will rise, therefore you can mount the motor higher. This inturn will give you better performance and economy.
boobie
Re: Motor Hiegth
You are correct but you're going to have to experiment with it as every boat is different.
Jlawsen
Re: Motor Hiegth
Correct. It also depends on which lower unit you have, what type of water pickup you have (standard or low water) and what prop you're running. Bass boats typically run on a pad (delta pad) so that is where you'd start with the 1" above measurement.
emdsapmgr
Re: Motor Hiegth
When you start to play with engine heights, probably best to invest in a water pressure gauge. You won't be able to see if you have the engine mounted too high-and the top water inlet holes are running out of the water. The gauge is an engine lifesaver for anyone running a jackplate.
Dhadley
Re: Motor Hiegth
The rule of thumb is you can go up 1" for every 5" you go back. If your boat has a stepped transom you can go up slightly more perhaps. Your final X dimension is a marriage between hull design, prop technology, balance and intended use.
joeken
Re: Motor Hiegth
Thanks guys for the info. This helps alot. I will play with this and see if i can get her going. I still could use some info. on a spot to drill and tap for water pressure pick-up on a 1980 115hp TLCS evinrude.:)
Daviet
Re: Motor Hiegth
You should be able to tee off of your tell-tale for a water pressure guage.
