Motor over revving
shaunknee
Hi all
I have an ?85 Mariner 2S 25HP. I?m thinking the pitch is insufficient for my motor. At full throttle I think my rev-limiter is kicking in.
My current prop is a 13P (48 4356 A40L 13P stamped)
I did the timing on the back of a large boat and the motor runs great at full throttle. It even gets a 17 foot boat up on plane. The problem is when I put the motor on the 14f inflatable I want to use it on. At full throttle it stops firing / runs rough on the small, light boat.
I know I should get a tack, however I was wondering if I increased the pitch by one or two more I might solve my problem.
I was hoping for a pitch suggestion.
Thanks
rndn
Re: Motor over revving
It's really hard to tell if you need 2 inches of pitch or 8 inches of pitch. If you want to buy a prop with 2 inches more of pitch and find out that you still hit the rev limiter and then buy a prop with 4 inches more of pitch, etc, etc. Even if you can get a loaned prop you really still will not know if your motor is over-revving. Try to find a local marina that will hook up a test tach for you and also suggest the right prop. For your reference for every 1 inch of pitch change you should see about 200 a rpm change. Add 1 inch drop 200 rpm's, reduce your pitch by 1 inch and add 200 rpm's.
shaunknee
Thanks for the response rndn
If I wanted to try a prop with 2 more inches of pitch off ebay am I looking for a 15P with a certain diameter and spline size ?
Thx
rndn
As long as the prop is designed for your motor you should be fine with spline and diameter. A larger or smaller diameter has very little effect on the performance, so be concerned that it will fit and that the pitch is what you are trying to get.
rndn
As a rough guess, I would think the motor would still over-rev by adding only 2 inches. A 25HP pusing a 14 foot inflatable is a lot of motor for a little bit of boat weight. If you're over revving at 13P, if you're just going to try something, I would jump to 17P. Most outboards have a 500 to 1000 top rpm range so you do have a little wiggle room should you need while still keeping the motor operating within the suggested guidelines.
shaunknee
Thanks for the advice. I'll try a 17P. This motor seems to explode to full power. It is amazing how such an old motor can produce so much power.
