motor ran fine last year
stylesabu
bought another boat, so my 16ft 75 hp suzuki has sat all summer and last fall also. went out today and it won't go over 3000 rpm.it ran fine when i stored it. I switched fuel pump no differance. primer bulb seemed to get a little soft but 2-3 squeezes it firmed up. what kind of fuel pressure am i looking for at carb line? I think its a carb issue.starts right up idles as well as a 3 cylinder will.but when i try to open it up it falls on its face. as i ran it longer at 1300m rpm it seemed ok, i did try to open it up after about 2 hours almost came up on plane. I think I got crap in my carbs. I didn't have any way to enrich it. Ideas/
SparkieBoat
Re: motor ran fine last year
sat up for a year..I think a carb rebuild/cleaning is what you need, make sure to do it right.
99yam40
If it is running lean you will pop a piston if you keep running it.
Clean the carbs
jayyyy
Usually fuel systems are the culprit after extended lay up. I think your on the correct path. I would check simple things first, fresh clean fuel, tank vents, fuel lines maybe run boat with fuel system cleaner/ h20 absorber like startron or similar.
stylesabu
cleaned carbs, that fixed the problem.top carb alot of sediment 1/4 tsp,middle carb had some gel? bottom was fairly clean.
you have to love ethanol in the fuel. it breaks down in less than 3 months. your best bet for storage is pure fuel for 6-9 months of storage, or completely draining the fuel system for long term storage.
SparkieBoat
use sea foam or stabil marine for over 3 weeks storage..double dose it if it will be longer than 3 months. triple dose it if it will be all year. carbs are much more forgiving than injectors.
mommicked
This title sounds like what I imagine every marine mechanic in the world hears everyday in the spring!:D
SparkieBoat
yepper...I may just open me up a shop this spring, could make a good living just cleaning out carbs.
stylesabu
yea all my two strokes have this problem. every new season, I'm cleaning weedwacker, tiller, lawn mover, carbs. and I use stabil. So I need more for storage? or stabil and seafoam
SparkieBoat
triple dose for long term storage up to a year. sea foam is great, stabil marine ethanol is good also.
