Motor tilt switch
Yori
I have Johnson 65 hp. OB. The tilt switch suddenly quit. no sound and stay at up position. Is anyone can help me?
Daviet
Re: Motor tilt switch
What is the year or model number of the engine are you working on?
Yori
95 I guess, I just bought this boat and the engine, and I have not used it yet, the tilt switch ( red button on the shift lever ) worked ( 2 stage = fast to go up and down, then slow to adjust bow angle)
schematic
if it does not motor either up or down, try tapping the motor with a plastic hammer while holding the down button. There are several things that can cause this, but it is often brushes worn or hung up.....
Yori
Thank you guys,
I've got fixed !!
The problem was a wire connection. There is a black box that holds wires to the lift motor, and one of the wire was corroded. I changed the wire and it worked perfect !!!:)
