I have a 1974 70 hp Esl that has just been rebuilt. It has 125 psi on all 3 cyl. It has good spark done with a professional spark checker, new plugs, fuel pump is pumping good(no leaks anywhere), carbs have been rebuilt with new needle and seat. Timing is at 24. It runs fine on the muffs at the house and idles fine. When I take it to the lake it idles fine around 900-1000rpm, but when I put it into idle drive(first notch) or idle reverse(first notch) it will run for a little bit then quit. Then I have to give it some fast idle and CHOKE it all over again just like it was cold even though it has run for a while.......? not good for trying to load it on the trailer!
