Moving Batteries Forward - What type wire
83mulligan
Hey all, going to be relocating my batteries about 10 ft. forward from the back to middle of boat. What type of wire do I need? I'll be using 2 ga. Does it need to be marine Tinned wire or will the copper from lowes work? Its a freshwater trailer boat stored indoors.
Auger01
Re: Moving Batteries Forward - What type wire
Do not use the house wire from Lowes. :facepalm: It is too stiff. The vibrations encountered in a typical boat will cause it to fail. Use a battery cable. For a freshwater boat, it doesn't matter too much if it is tinned. You can get listed boat cable that is not tinned, but most of it will be tinned.
colbyt
Master Chief Petty Officer
Fresh water and indoor storage, I would use copper. How many amps? #8 is okay for 50 and #6 is okay for 60. The tinned is always best. UF is second best and regular is third.
83mulligan
I don't know how to tell how many amps for the 90 HP Johnson or the Yamaha T8? Each will be on its own battery. The 90 HP has 4 GA battery cables.
83mulligan
Am I best off running the same ga wire from each motor 15 feet to the batteries or am I ok with making a butt splice and going up one size wire from there for 10 ft.?
IE, on the 90 horse butt splicing from 4 ga existing to 2ga and on to battery
Auger01
I am not sure you can find a butt splice to go from 2 to 4 ga. I used one of these to "splice" my 2 ga battery cables to the motor wires. It worked great. Bigger is better. Use the 2 or larger to go to the outboards.
Dual PowerPost - Two 5/16"-18 Studs - Blue Sea Systems
83mulligan
Thank you, Auger01. Now i just need to decide if its worth paying significantly more for tinned battery cable vs. copper battery cable in a freshwater/stored indoors trailer boat application.
83mulligan
how do i test with my meter how much amperage my motor requires?
bruceb58
You can't unless you install a shunt and measure voltage drop across it.
Best to consult the manufacturer or see if the manual mentions anything. Someone on here may know this already. I am not familiar with what outboards draw.
