Re: Multi function gage question
its done by the tach pole setting. v4 and v6 both use the 12 pole setting. unless its the newere one with dip switches. then it must be set to the proper 6 or 12 pole position. but even then its interchangable between v4 and v6 2 strokes with no changes nessasary unless the newest motor is a two wire trim sender. what are ya trying to do ?
