FloatsLikeARock
Thread starter- Joined
- Jun 1, 2022
- 23
New guy here, and I Just bought a 2000 Procraft 170C with Mercury 125 ELPTO 2 stroke.
The boat has lived outside on its trailer a lot (fresh water only in the Southeast). It has several intermittent electrical issues. First were NAV lights. Bulbs were shot, so I installed LED replacements. Would not work or would intermittently only show dimly. I traced this to a thick layer of tarnish on the brass connectors in the sockets for the light poles. Fortunately, I was able to remove the connectors and clean them with a wire brush. Cleared up the problem.
Now though, out on the water, the fuel level gauge and the tachometer will intermittently stop working. More alarming is that the the engine will intermittently lose power and die. I'm almost certain that these issues are a result of similar tarnish/corrosion on the crimp-on spade connectors on the back of the dash, and maybe elsewhere. I'm sure I'm not the only one who has experienced these kinds of issues.
I was thinking of removing the dash (no easy task) and hitting every connector with some Caig Deoxit. Maybe using pliers to squeeze and tighten the connectors' grips on the spades. Maybe even solder some of the suspect or critical crimp connections.
Is there any better or easier procedure that has a chance of restoring reliability to these electrical connections.
