frankttaylor
Thread starter- Joined
- Apr 3, 2012
- 100
Hello. I was replacing the anodes on my outdrive and one of the anode below where the hydraulic hoses on the stern drive connect. It also came with a gasket and a little rubber item that shaped like a mushroom that has a hole-in-one in and then goes through most of the length of that item. Since I was down there I pried out the old one and realize that it must be seated in there and trying to figure out how do I replace it with the new one. Do I need to disconnect that fitting that the hoses are connected to? If so I assume I need to lower the outdrive because I will probably lose hydraulic fluid? What is that item do? Or what is its function? What is the gasket for? Does that go between the anode and that fitting or does it go inside when I remove that fitting? Thank you for your help.
