Hi everyone. I am getting ready to do my first project and I wanted to ask for advice/suggestions/moral support/past experience. I have pictures and a plan of attack. Please let me know what you guys think.
The boat was custom built in 2004 by a man that once worked for stauter boat works. If you are not from lower Alabama, you might not be familiar with these. It is a great flats boat and I am looking to restore it.
Plan #1:
The white rub rails have been scuffed pretty bad and they need repainting as well as rub rail caps. I am hoping to put the SS caps on but they are rather pricy. I am planning on sanding the rails down to bare wood. Then I will prime them with prekote primer ( 2 coats) and then 2-3 coats of polyurethane brightside paint.
For the wood that is varnished I am a little lost at what to do but here is what i came up with. The bow is teak or cyprus (I think), but everything else is plywood. I was planning on sanding everything down(not the deck), then using interprime sealer ( 2 coats) and then 5-6 coats of gold spar varnish.
Questions?
Do I need to treat the plywood(not the deck) differently than the wood on the bow?
Also, what grits would be appropriate(general guideline)?
Pictures:
http://s622.photobucket.com/albums/tt310/fox16/
(let me know if these pics dont work)
Plan #1:
Questions?
Pictures:
