Re: My First StarCraft; 1975 18' SuperSport
I'll start with the downs:
I started scrubbing the bottom hull skin...and the stress crack problem rivals what I found.
The corrosion from the layer of epoxy + having multiple water intrusion points (and a bilge pump that didn't work) caused a significant amount of damage to the hull skin.
On the SB bow hull skin, you'll notice 2 pits that corroded completely through...that the PO covered with black flex seal.
And this is after some wire wheel work on the port-side hull skin...it's like this pretty much everywhere to varying degrees.
Once I collected myself (
and quit feeling sorry for myself :lol
the plan is clear. After the patching, leak tests/fixes:
- SS wirewheel the entire bottom skin...remove all of the AlO2
- Clean with dilute muriatic acid (concentration is TBD)
- Neutralize with baking soda
- rinse like crazy (trace amounts of muriatic acid would be bad news)
- Fill all of the pits with Marine Tex
- gluv-it the interior rivets / seams
- prep aluminum for paint (probably 50/50 vinegar/water) + rinse
- self-etching primer on entire interior bottom
- Rusto prime/paint the interior bottom
