my first time replacing a transom were to start
jonesg
Re: my first time replacing a transom were to start
Section the wood by setting the depth on a circular saw to just shy of the glass, removing sections with a chisel is easier.
Once you have one square removed you can attack it sideways with a wonder bar (small flat crowbar) and hammer, try 12" square sections.
fastryker
Thanks for the info. That helps me too as I'm new here, and have to tear out and replace a rotten transom as well. Good question and answer! I will probably start a thread soon and be asking for lots of advise from the masters. Thanks!
Woodonglass
Welcome to iBoats!
You're gunna need a 4 1/2" grinder too!!! I like using a backup pad and 24 grit sanding discs. Makes short work of left over wood chunks and resin build up. MAKE SURE!!!!! to wear gloves, goggles, and a GOOD QUALITY respirator NOT a dust mask. Long Sleeve shirt or even better a Tyvek Suit
69rrvert
Welcome to iBoats!
X2 on the safety equipment, especially the respirator. I have a full face that I use but a half face will work. Be sure and keep the gaurd on your grinder. The 36 grit sanding disc removes skin and meat in a flash. As for cutting the perimeter of your transom, you may get you a Dremel Multi Tool. That is what I used to get mine out. Good luck with your rebuild. Thanks, Steven
This is why you wear a respirator and Tyvek coveralls while grnding or cutting:
This is what happens when you remove the grinder gaurd. This was two days ago (lol):
nemo2011
that my friend looks very Painfull!!!!!
69rrvert
Actually, the initial hit was a little eye opening but it never did bleed. Needless to say, I went and bought a good pair of leather gloves and put the gaurd back on before finishing that side of the stringer. That 36 grit is a meat eater. Thanks, Steven
Bifflefan
Once your into it, its not a hard as you would think. Take your time and think each step through and you will do fine.
If yours is like mine you will need to make a jigsaw puzzle of pieces to put back in and then glue and screw them together as added. I had some pics in my photo album on here but cant seem to locate them now.
wavebuster1
thank you guys i will be adding pics and most certainly more questions tomorrow
rickryder
Welcome Aboard wave! Plenty of threads on restorations to read! Friscoboater's is very good with videos and oop's hull extention thread is killer!! Mine has some good details also..... so many with great info :D Happy reading.
You have now entered the DRY DOCK!!
wavebuster1
do i have to cut out a section of the floor to get all guts of the transom out or is there a way around that. and thanks for the welcome i would post pics but i dont no how to
Woodonglass
Wave,
My signature has a link on how to post em. Make sure your Settings are set correctly
Cadwelder
Will need pictures of your bilge area to answer that question for sure
wavebuster1
View attachment 93027 i just realizes this is a horrible picture but that is all the progress to date. in the morning i will take a better 1 now that i know how to post pics thanks wood
ezmobee
Pic doesn't show
wavebuster1
please bear with me i trying to upload pics
ezmobee
Still can't see them. Use photobucket.com. At least then I can help.
