jpmurphy
- Joined
- Jan 14, 2009
- 358
I'm about 75% done with the initial sanding and decided to pick one section to sand down to the finish just to see how things would look. I started with the high grit paper and worked down to 220, then 600 and finally 1500 grit hoping this would get the finish I want. The heavier grit papers are the regular color, the finer grits being 220, 600 and the 1500 are black paper.
Everything goes well until I start with the black 600 grit paper then I start to get black steaks. It gets worse with the black 1500 paper. Once I stopped sanding I washed the spot with 50/50 distilled vinegar, let dry, and there are still black streaks which are noticeable.
The pics don't show the streaks very well, probably due to the flash being so bright. But I can see them all the same. Other than washing after the last sanding, I am at a loss as to how to get rid of these streaks. I haven't done the steel wool polishing on this test section yet as I wanted to see what you folks had to offer concerning these streaks.
As always, I really appreciate your help. :redface:
