Mystery Motor Good news and Bad News
sevanseriesta
Well I have this 1970 Johnson 115hp motor that I got for my ps3. I thought that was a steal even if it did not run came with boat controls also. So tonight I thought I got all the wires reconnected so I decided to check the compression. Here part of the news
158 158 162 158
I was estatic. So much that I went and borrowed another Compression check tool to verify mine was working correctly. No changes.
Bad news, No spark. And since I dont have a book for my motor I have no idea where to start. Ignition pack looks brand new. everything else no idea.
Im glad I dont have to rebuild the motor. I thought for sure a ring land or a rod would be broke.
Still have not tested water pump yet. Baby steps, they always say take baby steps.
sevanseriesta
Re: Mystery Motor Good news and Bad News
Anyone got any ideas that I can check before I have to start buying parts?
AlTn
you realize a factory workshop manual is really a wonderful thing..short of that all I can point you to is cdielectronics.com/troubleshooting, find your ignition system, and commence in
sevanseriesta
Yup still working on getting one. Just seeing if anyone can help while I wait for it to get here.
HighTrim
You dont have spark to any cylinder?
have you tried disconnecting the black/yellow wire at the pack and re testing? It is the kill wire.
sevanseriesta
I dont have any spark to any cylinder, and I can not find the black yellow wire anywhere. Where exactly should I be looking for it at.
sevanseriesta
I did, but again I do not have the manual for the motor so I am not sure where the items that are on that sheet are located at. I do appreciate the information, hopefully when I get the book all that will make much more sense.
sevanseriesta
And by the way I have looked at my motor three times and I can not find a black wire with yellow stripe anywhere. Is this wire coming from the boat controls. If so keep in mind that the motor is not connected to anything right now.
Davem3
ummmmmmmm, yes by all means hook up the controls please.............
sevanseriesta
I thought you did not need the controls hooked up to test compression and spark
Davem3
compression, no.......... spark and running the engine, yes ...............
sevanseriesta
So then would I be correct that, the key needs to be in the on position. Or should I start it with the key instead of jumping it
boobie
This mtr has no black/yellow wire coming from the pack. It's battery cd. The key has to be on to feed B+ voltage to the power pack which makes the system fire.
sevanseriesta
Thanks Boobie Appreciate the reply. I was getting ready to take off the Flywheel so now I have to find a socket the right size to torque it down.
Also does anyone know what the right oil/fuel ratio is for a 1970 johnson 115hp
boobie
Socket 1 5/16 ". Torque 100-105 ft-lbs.
