Mystery Parts
Joker757
1999 7.4L MPI. Anyone know what these sensors are? They weren't hooked up when I removed the engine.
Re: Mystery Parts
Ayuh,... The Big 1 on top is the Oil Pressure Gauge Sender...
The little 1 on the bottom is the Low Oil Pressure Alarm Switch....
Rocky_Road
Re: Mystery Parts
The big one is the oil pressure gauge sending unit...the small one is the oil pressure switch (for the audible alarm system).
45Auto
Re: Mystery Parts
I guess we know why you had to remove the engine now - it lost oil pressure and you didn't know it!!!!! :)
TilliamWe
Banned
Re: Mystery Parts
Yep, I was thinking, "Geez, I hope you didn't pull the motor cause the oil pressure guage read 'zero' and the alarm was going off. If you did, you wasted a bunch of time, money, and energy!"
Joker757
Re: Mystery Parts
on second thought they must have been hooked up because I was getting OP readings at the guage. The mechanic that started the work on my engine may have removed them. I pulled the engine mainly to knock off the rust and paint it. Also wanted to clean/paint the bilge. Thanks for the info guys.
:p
