need a little bit of info plxs on 115 merc 1979 6 cyl
slash123
ok i got this boat while back fella screwed me but i got to run today after replaceing stator swithbox and triger but its not pumping water in nuetral so i wonting to know is it supposed to ??? 1979 merc 6 cylender115
Chris1956
Honorary Supreme Mariner
Re: need a little bit of info plxs on 115 merc 1979 6 cyl
It should pump water all the time. That motor has no thermostat, so pumping should begin 10 sec after starting it up. The telltales clog easily, so observe water exiting the gratings above the antiventilation plate. If you see it there, the motor is pumpng.
slash123
thnks ill look at it after hunny duuuu list i just want to get the thing in the water goshhhhh so many things wrong
CV16
I keep a piece of weed whacker line handy to shove up the telltale hole to unplug it.
