Benny1963
- Joined
- Sep 17, 2006
- 1,476
Re: Need advice on 235 Johnson cooling, and shifting.
the hook will be pointing forward towards the boat .
remove your airsilencer all the way to the carbs
in there you will see a shift arm that hooks to your controls.
at the end of the arm under bottom carb you will see a prong that has groove in it and hole for your shift link its under bottom carb .
prob logging off , but will check if you post in next30 min
be back on tomorow.
benny 1963
be back on tomorow.
benny 1963
