bigdave438
Thread starter- Joined
- Oct 18, 2010
- 43
hi to all....can any one help me out with this camshaft sealed power speed pro cs-1043m? whats its rpm range..and is it worth keeping...i have a 1982 carver santa cruz 2667, , 5400lbs,,,alpha 1 gen1... And a new engine i just installed 350 sbc 5.7 bored.30 over, ,,thunderbolt iv ignition,,,new flat top pistons,,new crank shaft,,,high volume oil pump,,,brass freeze plugs..new hydralic lifters and push rods,,,882 heads with new valves and guides and springs...three angle valve job,,,all rocker studs pined in.......intake manifold is off my old 260 mercruiser,,,and also the 4 barrel rodchester carb....i have the cams spec sheet but it doesnt state any rpm info and no horse power info...ive searched all over and no luck...i even called the manufacturer and they didnt have that info..so that tells me its a discontinued cam....so im reaching out to all the wise gurus here...thank you in advance....also is it worth keeping this cam or getting something better for my application like sum-k1102 from summit racing...
