jorgeoliva
Thread starter- Joined
- Jun 27, 2015
- 143
I think its probably the neutral switch cable had to replace the rack and pinion Teleflex cable maybe that moved something behind the panels. is it possible to by pass the neutral switch and go directly to the solenoid here is what my switch loos like
alldodge thank you for your help. so how do I bypass the neutral safety switch
so basically your telling me not to remove any wire from the solenoid just add a ground cable to the yel/blk see picture and this should bypass the neutral safety switch and start the engine with my key
