180Diablo
Thread starter- Joined
- Mar 8, 2007
- 76
Reason for replacing my dash switches are, the threads on the outside trim ring have snapped on 3 of my switches. So rather than hold onto the switches with my hand behind the dash to switch it, I need to replace them. As far as I can tell they all do work, because the illumination works.
http://ww2.sierramarine.com/sierra/...s and Accessories&prod_title=Toggle - Tip Lit
The above link is the design/type of my switches on my dash, but I was a little bit confused on if I needed single or dual circuits for my two dual use switches.
My guesses for which are the correct switches for my boat are:
Blower: ON/OFF SPST
Nav / Anchor: ON/OFF/ON DPDT (or is it SPDT?)
Bilge: ON/OFF SPST
Interior Lighting / Acc: MOM. ON/OFF/ON MOM. DPDT (or should it be on/off/on ?)
Horn: Mom ON/OFF SPST
My interior lighting as well as the accessory switch, im not sure if it's supposed to be momentary on/on, but thats how that switch is appearing to be working currently. It will not stay in up or down position. The nav/anchor light will stay in the up or down position however.
Last weekend I did jot down the locations of the wires on each switch, however I did not jot down the # of poles on each switch.
thanks to any replies.
Blower: ON/OFF SPST
Bilge: ON/OFF SPST
