FBPirate95
Master Chief Petty Officer
- Joined
- Apr 15, 2009
- 840
My outboard has the following lower unit:
http://www.sterndrive.info/outboardmotor/v4_90_small_gearcase.html
I have obtained this lower unit:
http://www.sterndrive.info/outboardmotor/type_o_v4_v6_large_gearcase_id.html
I have swapped the lower units and everything appears to be fine except the shift rod length. I'm not able to achieve the 21 27/32 inch shift rod length on the newer lower unit. I was thinking I could extend the shift rod so I could get the right length. My question are: Is there any problems with running the larger lower unit on my 90hp? Are the gear ratios the same? Will it negatively effect the performance of my outboard?
