alex3012red
- Joined
- Nov 20, 2006
- 65
I have a 92' bayliner 24'52 classic, w/mercruiser 5.0 lx alpha gen II. I noticed that water was entering the hull thru the steering arm only when i rev the engine. Boat is in the marina (salt water), i also looked at the outdrive and the mercruiser sticker on the transom plate above the water line has a hole and show a little corrosion. the guy that bottom cleans it said that the outdrive looks to be o.k no corrosion. I have no idea whats under the sticker, if anybody has a alpha outdrive dissasembled picture or drawing, to see what i need to replace or fix. by the way the steering arm has corrosion on it. anyhelp would be appreciated.
thanks
Alex
thanks
Alex
