basszzilla
- Joined
- Feb 28, 2003
- 71
my fluid keeps getting very foamy with one raise and lower of unit. what i dont understand is that if sits for about an hour, after trim tops out the pump motor seems to bog down, after working up and down a few times it works fine. when the motor strains i can her what sounds like a vacume leak from somewhere but i cant identify. i have used every method i can think of to find what i assume is some kind of a leak. i am no novice at hydaulics and have been through the tilt cylinder and valve body twice with no change in service, and still get this hissing sound and frothy fluid. i have used tilt fluid, atf and non detergent 20w oil. the unit does not creep down like you might suspect. i started this repair job to repair a substantual leak at the top of the tilt cylinder when the unit was working fine. when i resealed the tilt cylinder the shaft was slightly pitted so i worked it with 600 grit and tilt fluid and does not leak. it is obvious i have done something wrong, i just cant figure out what, any takers?
