floatmiboat
Thread starter- Joined
- Sep 4, 2010
- 90
I just bought this 1995 mariner 2 stroke 4 hp motor[ serial #D976775] and I've been having starting issues with it. I thought the fuel was leaking out from the tank hose connection but, now I see a puddle under the carb. I can start it with the fuel shut off but, shortly after I switch it back on the carb floods and fuel spills out of a hole next to the mixing chamber opening in the carb. If I pull on the cord again more fuel spills out. What is causing this and how do I fix it. Also how do I adjust the idle mixture screw? it has a spring under it , do I turn it in until lightly seated and back it it out 1-1/2 turns? Thanks in advance, anxious to go fishing.
