Need help with motor
achris
More fish than mountain goat
Re: Need help with motor
Sorry to say, but that number comes up as a 1981, not '91....
Which plugs were clean?
Chris.......
achris
Numbers 1 and 3 are on the same switchbox... Just for S&G swap the wires that go to those coils.... See how you go... Just an (educated) guess... Easy to do and won't hurt anything if I'm wrong....
Chris........
narvlebenoit
S o Chris.early I was reading a forum were you said a stator may vary in temp.so it may be my stator holding me to 4000 RPMs right now in the cold temp. because in the summer is when I was getting 5300 RPMs at wot so maybe my stator going bad .....Narvle
achris
What you were reading was me saying that the resistance of the windings varied with temperature, not the performance.
There is a seasonal variation but it works the other way... Better performance in cooler weather... That's because cool air is denser than warm and that means more oxygen available in each charge....
Have you done any further diagnostics as to your problem? One that I would do, but it needs 2 people. Run the engine at high rpm and, with the engine cover off, CAREFULLY put your hand (or something flat) over the air intake of the carbs, one at a time.... If you get an increase when you cover one of them.... You have a fuel problem..... and you've even isolated which one... :D
Chris.........
narvlebenoit
Thanks Chirs may get a chance later today to give it a try .
narvlebenoit
Chirs had time to try the hand over the carb today nothing changed but notice that the carbs are dripping gas out of the front .only getting 3800RPMs right now.but its jerking like it wants to go but dont . tryed riching up the carbs.but no change.put timming light on plug wires their all firing .checked all grounds and wires on new CDI switch boxes.starting to get depress don,t know what to try next . Thanks for all the help you guys been giveing me .
narvlebenoit
took out all the plugs their all super clean mustbe water but were would it be comming from.
narvlebenoit
how do I get to it by taking off the power head or is their a easier way.Thanks again Chris.
achris
Sorry, the only way it to remove the powerhead... The off with the outer exhaust covers and that gives you access to the inner cover. Before you remove the inner cover, have a look at the gasket surface area, you'll see washed areas emanating from the gasket... That's where the water's getting in... Remove that cover, clean all the surfaces and put new gaskets in, and epoxy the bolts in, and you're good to go. While you have the powerhead off, replace the 2 lower crankshaft seals.
Chris.....
narvlebenoit
Thanks for the info Chris Igess its time to go to work. Nice fish in the picture on your profile don,t have them in fresh water here In Louisana .Thanks Narvle.
narvlebenoit
Finally got it running right it was the trigger .Now all the Elec. is new THANKS for all the help Guys.
narvlebenoit
hey guys battery wont charge right of way takes a good while for the amp gauge to go up after first starting it even if I put battery charger on an battery is fully charge.everthing is new but Recterfire so i gess it is bad how to check it. Thanks Narvle
