Re: Need help with motor
Sorry, the only way it to remove the powerhead... The off with the outer exhaust covers and that gives you access to the inner cover. Before you remove the inner cover, have a look at the gasket surface area, you'll see washed areas emanating from the gasket... That's where the water's getting in... Remove that cover, clean all the surfaces and put new gaskets in, and epoxy the bolts in, and you're good to go. While you have the powerhead off, replace the 2 lower crankshaft seals.
Chris.....
