larry dahl
- Joined
- Aug 11, 2002
- 7
I mix the gas 50 to 1 and it started and ran. the motor is new to me.
How can I tell if the water pump is working? Should I see water squirting out a hole some were?
I pulled the bottom plug on the lower unit and there was no water however the oil was not vary thick and blue/green. It looked like the kind of oil you mix with the gas. What lube should I get for the lower unit? I will change it.
Larry
northern Minnesota
Larry
northern Minnesota
