need magneto coil
kjburr
Motor is a 1972 55hp flywheel magneto engine 2 cylinder. After recent posts and much checking of the ignition system i am convinced that the 2nd cylinder coil is bad. It also broke off the spark plug wire hehe. So the coil is done, and I am in need of another one. My question is where are there any available and what engines have it that will fit mine? Engines serial number is 555HF. Thanks in advance..
tater76
Re: need magneto coil
Do you have 2 magneto's under the flywheel? and two black coils on the side of the engine? I have never heard of that its usually one or the other, but if you need a new magneto try Franz at franzmarine@aol.com I have a 1973 55hp Model 555HF, I just converted to stator ignition from a 1985 50hp Force.
Frank Acampora
Magneto coils from almost any early year Chrysler 35, 45, or 55 will fit. In fact, if you can find a junker, the whole magneto plate and points assembly will swap.
If you want a new one, you can try franz at franzmarine@aol.com or Standard Magneto Sales, 4119 West Grand Ave, Chicago. Il 60651 1800 624 6386 New ones are not cheap!
jerryjerry05
valleysales@charter.net Valley (989) 366-8178 This guy has a lot of older motors on site.Best to call.
Fill out the profile.Calling Valley might be hard from Australia or Africa:)Jerry
