Re: Need picture of AQ260 firing order....
You don't have to pull the valve cover to find TDC on #1. All you have to do is pull a spark plug out. I usually stick the hose from the compression tester in it and use a remote start button to bump the starter over. When you feel compression building on #1 cylinder, start watching the timing mark. As soon as it lines up with 0, you are at #1 TDC.
Now, look at your rotor, it's pointing to where #1 is for how your distributor was installed by a previous owner or mechanic.
Since you have backfiring, you are either off on where #1 is or you are using the wrong firing order.
Look at my first reply, I gave you the proper firing order for an AQ 260. I know for a fact it's not 1-8-7-2-6-5-4-3,
