FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Could someone please supply me with the proper timing specs for this motor.I know that there are 3 marks on the flywheel,but not sure what the marks degrees are.I believe in previous posts I have seen 28 and 32 degrees discussed.
Hey Marine Doc,first off let me say thanks,for all of your help to me and all others in need in this forum.Secondly,,what are the 3 timing marks on the flywheel.My motor has the middle mark highlighted in white,is this 30 degrees.What are the specs on the other 2.Also,I want to order a manual this week,what is recommended,Seloc or Clymer,,,thanks again.
If I remeber correctly...The longer line on the flywheel is to mark TDC for the pointer. There should be another line 1/5 of the way farther around the flywheel that is used to time the engine.<br /><br />This does not really matter though. Hook a timing light to #1 and you will see what to do. They are quite simple.<br /><br />TMD
