Need to identify the year of this 200 outboard, 20 hp
Force 120
Hello,
Please help me to identify this 200 mercury outboard. There is no serial name plate anywhere on it.
I attach some pictures of it. The compression is 110/115 psi and has strong blue spark but I could not remove the lower unit out of it to change the impeller. Two nuts have been removed.
Those decals were used in 1976 and 1977.------There is ( hidden ) a third nut / bolt.----Find it and the lower unit likely will fall off.
Force 120
There are two nuts have been removed and the third bolt on the top but I could not get any Allen key to fit on. Any suggestions to get this bolt out ?
GA_Boater
I think the allen bolt is 3/8". All my Mercs are that size.
A serial number is more important than the year of a Merc. What serial number is on the plate between the transom clamps?
There is a bolt hidden under that trim tab.------You have to get this tab off.-----Or bring it to a shop!
Force 120
Finally locate the third bolt which holds the trim tab. This is 5/16" socket head cap screw. Then there is a third nut behind the trim tab. After removed it, the lower unit came apart. Note: could not find the serial number anywhere on the motor.
GA_Boater
It's on that plate.
