Need to know what I can do about these cracks/chips..
proshadetree
Re: Need to know what I can do about these cracks/chips..
Get off the couch and just start tearing in. Try to save everything you can Stop when you see the inner hull replace all rot with good untill it looks like before:eek::D:D Best advice I can give Untill I know what exactly you need help with
Woodonglass
There are PLENTY of theads here on the forum describing and showing the process for removing and replacing the deck on a boat. Just do a search using Deck Replacement or Removing the Deck and you WILL find what you need.
I'm just sayin...:D
DK in Chicago
lol Ya, I hear ya.. ;)
Just wanted to be sure...
I'll take pics!! TBC
proshadetree
Can you access the spots on the bottom of the boat from the top? What do your stringers look like in that ski locker?
DK in Chicago
I don't see any wood anywhere that I can see without taking the floor off, when I pull back the carpet in the ski locker, all I see is fiberglass.. ditto for the transom...
The only reason I know my foam is soaked is because 3 of the 4 bolts holding the passenger chair to the floor came through the rotted floor which showed me a hole in the floor under where the pedestal was mounted. When I pushed my finger into it, water pooled up...
proshadetree
Well the floor needs to come out. Pull the puppy apart and show us where you are.
DK in Chicago
Sorry to be a total noob about this, but that is why I was asking before what is the best way to get the floor off??
Is the only way to saw it out?
Here are a few more pics of what I can see now...
DK in Chicago
I hope it's not that bad of a question, but how does the floor come up once I get the carpet up?
Pry bar? Saws-all? Unscrew it? Circular saw?
It's not located at my home, so any help as to what the best way to do this will be helpful, thanks!!
ondarvr
Yes to all, you will normally need to set a circular saw to the thickness of the wood and glass (no deeper), then cut around the out side edge. The other tools are used as needed. Do a search on the subject and you'll see some examples.
