need Wi-Fi whiz
lowkee
Re: need Wi-Fi whiz
Dont laugh...This is total Redneck.
I took and old satalite dish and removed the LNB (eye balls) then used a zip tie to hold an external antenna on the end of the arm. pointed the dish at the WiFi and got reception at around 500 feet. :D:D
Using that same method you can get a good 2-mile range. From what you describe, the antenna you made will likely get that distance if connected to your router and you have line of sight.
A cheap $10 fan shroud half will produce similar results. Redneck sounding, yes, but these methods work wonders.
H20Rat
Re: need Wi-Fi whiz
cantenna's are ok, just tricky to find actual foil lined pringles cans anymore!
another thing to watch out for, high db OMNI antennas are usually a bad idea. You are increasing the amount of noise you pick up in the same ratio as signal. Given a marina environment, you might get away with a good mid-db omni, probably not much noise, but on the other hand you might end up with less usable signal.
joed
Re: need Wi-Fi whiz
How to build a tin can wifi antenna. Use any tin can. It doesn't need to be a pringles can.
http://www.turnpoint.net/wireless/cantennahowto.html
starett
Re: need Wi-Fi whiz
I found that An ethier net device along with the focal antenna works great (links wet11 along with a cantenna or focal antenna
Cofe
Re: need Wi-Fi whiz
Will the can method work on a wireless N ? I noticed all these posts are referring to wireless G.
j_martin
Re: need Wi-Fi whiz
Should be fine. Wireless N uses multiple antennas on all components simultaneously. Wireless G uses multiple antennas and switches them dynamically on signal strength and quality. I found that out trying to set up a router with 2 antennas, one on each side of an RF impermeable wall. It was for a wireless telephone system. Man was that squirrelly till I figured out my mistake. One phone conversation would get cut off by another starting on the other side of the wall.
hope it helps
John
