new boat please help
StratosRob
Re: new boat please help
Follow the orange wires coming off your coils the will lead you to the power pack. Do the repair on the fuel (fuel Line,bulb,pump,Carbs, ect.) then move to the fireing. Just remember take these guys word they will not steer you wrong. Just remove one problem at a time.
ezeke
The powerpack is top center between the cylinder banks. The coils are arrayed across the top of the engine on a rack. The wiring looks like this diagram:
well update....today i had it on the muffs still will not run without choke on. so i decarbed the engine. and then i noticed fuel leaking fro one of the lines. replaced fuel lines now will run with out choke on. taking out tomorrow to see if ok..
tashasdaddy
i'm not going to say it. yes heck i am what have they been telling you fuel delivery. now do the dang carbs, so you don't ruin it. running lean.
Joe Reeves
You state: "i had it on the muffs still will not run without choke on. so i decarbed the engine."
A engine that will not run unless the choke is on indicates that the carburetors are fouled. Decarbing the interior of the crankcase solves nothing in this situation.
Remove, clean, and rebuild the carburetors using complete carburetor kits.
You may have other problems BUT the carburetors require the above work first.
kenmyfam
I know you may not want to.....but clean the carbs !!!!!!!!
(You can lead a horse to water)
Joe Reeves
Gary..... Obviously fuel is getting to the carburetors as it will run when you have the choke on.
The carburetors need to be removed, cleaned, and rebuilt using complete catburetor kits. If you don't want to do this, the engine has no chance of running properly.
That single powerpack is part number 581731.
Standing in back of the engine and facing the spark plugs, the cylinders are number as follows:
2....1
4....3
You've been asked about the compression various times. What is it?
hmmmm....what i said was it is running good now, after i replaced all the fuel lines. i said it is running "without" the choke on.
