ezmobee
- Joined
- Mar 26, 2007
- 23,767
Re: new boater....2nd boat in 2 weeks!!...picked this up:
The motor has a charging circuit and will keep the battery topped off. They aren't real strong however so if you run a lot of accessories you might want to consider a dual battery setup. Best to keep the second battery charged at home on a charger.
Starting process for that motor: lift the warm up lever (gives it some throttle in neutral and advances timing), turn the key while pushing in on the key to activate the primer system. Once it fires you may have to push the key in a few more times to keep it running. Once it is staying running and revving up to the level the warm up lever is taking it to, lower the lever. Then you can put it in gear and go. Shifting into gear should be done swiftly and firmly. You will do this motor NO favors by easing it into gear.
Is the VRO system still being used on that motor or are you pre-mixing yourself?
