new fitting for drive oil res for older boats
Bt Doctur
Currently have in the works a fitting to replace the gear lube monitor no longer available.Used on MC1, Alpha1, alpha GEN II without the dribble valve assembly
With this redesign you will be able to use a trim pump hose , the lube res bottle from the GEN II or Bravo,bracket
i will supply the fitting ,everything else is available locally
contact by PM only
muc
"Retired" Association of Marine Technicians...
I don't know about other parts of the world. But here in MN, especially this time of year when the Muskrats teeth are growing and hurting them. Suggest that you wrap this hose with a S.S. spring or use the S.S. braided trim lines.
Adding a gear lube bottle is a good idea.
