Bt Doctur
Thread starter- Joined
- Aug 29, 2004
- 19,557
Currently have in the works a fitting to replace the gear lube monitor no longer available.Used on MC1, Alpha1, alpha GEN II without the dribble valve assembly
With this redesign you will be able to use a trim pump hose , the lube res bottle from the GEN II or Bravo,bracket
i will supply the fitting ,everything else is available locally
contact by PM only
