Re: New motor Won't Start
DEAR SAD, what did you find out about the crank key being at the 5o'clock position? you asked about the compression being low at 35 - 50 psi? YES this is way under. <br />A lesson), squirt a 1/2 teaspoon of motor oil into a cylinder crank it over, w/o the spark plug. retest the compression. (the oil seals the rings). if it increases the rings AREN'T sealing, for whatever reason. If the compression stays the same this points to elsewhere. A s s u-n-me-ing that the head is not cracked, head gasket is good, the same compression, (after the oil is injected), points to the valves not sealing. But these are new heads...Then I assume that the valves are sealing, IF they are adjusted correctly, in the first place... before you ever cranked the motor over. I asked, you never said. Are these hyd lifters or mechanical lifters? Very important. these things BEND. then your compression is not there. And your new heads are candidates for another valve job or the scrap! Another Question, did you oil the rings upon insertion into the cylinder bores? or did someone else perform this part? just checking. you should have minimum 125 psi with the rings unseated and most likley more.<br />I asked, you never said, do you still have your old cam? you can varify that the firing order of the camshaft is the same. if you question this. don't let it beat you. let us know. If my post confuses you, let me know, I will try to clear it up. ...sl
