Freezebear
- Joined
- Oct 14, 2003
- 93
I am the second owner of a Nitro Bass Boat with a 92 60HP Tracker Pro motor. I want to do everything right. I have gone through the entire boat making it legal and replacing all questionable parts. My philosophy is like this ---If your car breaks down, you can just get out and walk to the next exit, but if your boat breaks down, you won't be walking nowhere. There's only one person who can walk on water! <br />Well I changed the plugs and did a compression check. Got 115psi on all cylinders. Plugs looked dark that came out, but no wear. I am using QL77JC4 but according to chart I could also use L77JC4. What is the difference? The chart says to use the QL plugs if I have VRO, but I have mine disconnected because I'd rather mix my own fuel. So should I run the L77JC4's??<br />Also I changed the lower unit oil last night and went to WallyWorld to get some and was not impressed by the selection. I was looking for a semi or full synthetic, but could only get Castrol 80W90. I put that in but have not run it yet. Went by a Johnson dealer today to see what they have and picked up a bottle of Johnson Ultra-HPF. The Castrol stinks like any gear oil should, but the Johnson stuff is totally different. It hardly smells like anything. Should I dump the gear lube now or should I run it first then change it?? My trip this weekend will consist of about 25 miles. Will the Castrol burn up my lower unit?? <br />Also picked up a can of Johnson Engine Tuner Injection Can. It screw onto the schrader valve. There is a red lever there called the primer lever. It says to leave the lever in the RUN position. What position is that? I did not know I needed to mess with that lever. <br />My other concern is that the boat pulls slightly to starboard if I let go of wheel. Cables are all OK. The trim tab above the prop is all the way to the left if looking from the rear. I moved it 1 notch to the right. Will this clear up my problem or should I go more? Is there anyhting else I should check?<br />Thanks<br />Freeze
